Campin LI wrote:
GordonThree wrote:
6/3 or heavier for the future.
Thanks. I was thinking 8, thinking 6 is a bit overkill. Why 6? Does 6 fit in a 30 amp breaker?
Good thought about the breaker.
You should be able to do a quick "test" for fit at the hardware store before you actually buy anything.
I was thinking that the "for the future" comment was aimed mostly at the very real possibility that you might "upgrade" your RV in the future to one that needs 50 amp service, which has two 120 V 50 amp legs, which would require a heavier wire.
