tidalwave's avatar
tidalwave
8 gauge wire feed for truck camper?
My new Chevy 2500HD truck has a wire 'harness' tapped off the front-rear tow wiring for the truck bed. The OEM harness power feed has a 40 amp fuse rating. Will I have to run a separate 8 gauge power feed wire from the truck battery to the truck bed? I have a Bargmann 7 conductor right angle socket that I am planning on splicing to the OEM wire harness. Can I use the Bargmann socket wiring...or will I have to run the 8 gauge wire up into the truck bed separately?
I am also planning on installing a power solenoid relay to shut off the battery feed when the ignition is off.
