BugsRLB
Feb 25, 2014Explorer
"Be warned that Lance Campers require 8 gauge power feed and a Lance 6-conductor socket...you would have to run 8 gauge wiring if you use a Lance camper"
I had already done my wiring before I found out it is supposedly sitting there waiting for me. I got the actual Lance pigtail from an RVnet member. I ran the 8ga wire inside a garden hose (to eliminate chafing) an ran it along the frame directly to the battery with a relay. Ran the other wires in a garden hose and ran to the back of the truck and soldered them into the trailer wiring harness. It was along day but it all worked out well. It could have been a shorter day if I knew the wires were already there! :S Oh well!
