Oldtymeflyr
Feb 23, 2014Explorer
You do not need to run another power line if you have the camper wiring you have described. A wiring diagram for the wiring bundle should be in your owners manual. The wire will probably not be an 8 gauge wire, its smaller.
Our camper has the battery relay/isolator installed in the camper and will isolate the camper from the truck starting battery when the engine is not charging.
If your camper does not have a battery relay/isolator its probably best if you do install one either in the engine compartment or in your camper ahead of the camper batteries/electrical system.
Good luck.
Good luck.
