time2roll
Jan 20, 2018Nomad
If the tag says 13 amps load you can count on close to 130 amps from the 12 volt battery. (amps x10)
Best to stay away from parallel wires unless the inverter has dual input terminals. Get the right stuff. I posted a link above.
As far as equivalent wire you need to convert to circular mils to add the cross section of copper. But again try to stay away from parallel.
Cross section area is on this ampacity chart:
http://www.genuinedealz.com/voltage-drop-calculator
Need 4x #10 to make #4
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 22, 2026
