brulaz
Jan 21, 2018Explorer
SoundGuy wrote:opnspaces wrote:
As far as the distance, the horizontal run is not that far, more like 3 feet if I went straight from the batteries through the front wall of the trailer. But that seems like a leak point so I was picturing going down from the batteries, back to the trailer then up through the floor. Now that I have a better idea how much distance affects wire gauge, voltage drop, and price; I'm going to reconsider the path to see how much I can shorten it.
I wouldn't do that - if the inverter is mounted in the front pass through storage compartment go down through the floor, along the underside of the A-frame, and up to the batteries. In my case that turned out to be 6', meaning 12' of cable for positive & negative, both 4 gauge for my maximum ever load of 70 amps. You sure don't want to go through the trailer's front wall - instead increase the gauge of the cable to whatever may be necessary to meet your load & distance requirements.
Oh I dunno. That's what I did. :) As straight a path to the batteries as possible, carefully caulked.
But my front wall consists of a cap + space + interior wall. A water leak will just drain down the solid fibreglass cap. If that front surface were laminate ... maybe not.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
