enblethen
Nov 28, 2018Nomad
Look at your converter. Check for make and model. Find manual for it to determine charge rate.
You could be running genset for 12-15 hours a day in cold weather if batteries feed other 12 volt items.
The two batteries in question, are they also running the furnace and other 12 volt items? If so the inverter is the least of your problem!
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
