BFL13
Nov 28, 2018Explorer II
So your Vector will be fine for doing the recharging at its 12 amps with that much gen time.
You don't have much running from the inverter so low amps there. Two 27s should be good sounds like.
You won't be running from the inverter with the gen on anyway. ? If you do--make sure the Vector is on the gen (NOT from the inverter!!!) doing the batteries at the same time the inverter is pulling amps from the batteries. That will help keep the batteries from running down.
You do need a voltmeter at least to get some notion of when the batteries are down to 50%. "Resting" that would be at 12.2v BUT with any load on them, voltage will be lower than that, so you might think they are farther down than they are when showing 12.2. Maybe pick 12.0 volts with things running off the battery as your "target voltage" to stay above.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
