Larryect
Feb 15, 2016Explorer
So, it sounds like the main things that might tend to run at the same time is:
AC (or heat)
Water heater
Griddle
Fridge
Converter
I would add the power requirements for those items together, probably figuring the converter at less than full draw, add something for some cushion and then look for a generator that would deliver that. Also take into consideration a 120/240 generator is going to split the output between the two legs, and you may have more load on one or the other. An RV type generator would be able to provide all the wattage where needed if you used a 50A - 30A adapter plug, assuming less than a 30A load total.
You said you can run on 30 amps if being careful, so I think a 4000 W capacity would do it if you are willing to be careful. So, I would suggest a capacity of 4000 watt RV type generator as a minimum. Two Honda 2000's may be ideal.
But, if you don't want to worry about what is running, a lot more could be needed. I would worry the 5000 watt your asking about may not have enough power on both legs of the output depending on how the trailer load is divided.
I wish my Yamaha 2400 had parallel capability...... I converted it to tri-fuel, so I can hook up multiple propane tanks to it and run quite awhile.
AC (or heat)
Water heater
Griddle
Fridge
Converter
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
