wnjj
May 23, 2023Explorer II
schlep1967 wrote:wnjj wrote:swimmer_spe wrote:2112 wrote:
My gray tank is full when the shower no longer drains.
My black tank is full when the toilet burps when I flush.
My gray fills up long before the black. I put a valve on the main drain pipe where you connect the drain hose. With that valve closed I open the gray valve, wait a few second, then open the black valve to move some gray water to the black tank. Then close both valves. That gets me at least another shower before to the dump we go.
Do you have a picture of that setup?
Both of mine go to one main drain with drain valves for both tanks.
You can do this trick by just leaving the cap on the end but you will have to deal with the “extras” when you pull the cap to connect the hose at the dump.
DO NOT TRY THIS WITH JUST THE CAP IN PLACE!!!
People really should think before they post this stuff. If you want to use this method get yourself one of the twist on valves for the end of your drain line. That way you can attach the hose before you let the c r a p fly.
Thanks for the warning but it should be obvious I was “thinking” about it. This is why I suggested there would be extras to deal with. It’s just gray water left in there and won’t instantly kill you either. Many dump stations have a sloped pit that runs to the drain so it’s easy enough to deal with. I’ve known a couple different people who had use this method in a pinch. It’s not like you can “just install a valve” when you already are at a camp spot, late at night and your family cannot use the sink. Relax a little.
