jayspi
Oct 05, 2015Explorer
Empty Nest, Soon wrote:owenssailor wrote:
I have a 52 year old 38 foot sailboat. Over the years have had to do various repairs.
The best option is to cut out the rotted area, make a new piece to fit and then epoxy and screw it in place.
The next option is to use West System epoxy with their high density filler and fill in the area where the rotted wood was.
I tried Git Rot years ago. It did help but when I later took that area apart there was hard wood at the holes where the Git Rot was injected but still soft a few millimeters away.
If you have questions plse let me know
What he said!
There are several places that promote expensive thinned epoxy (CPES, or similar) as a miracle snake-oil to make sound wood out of rotten wood. Baloney! There's no way to get it to penetrate far enough to do much good. If you want to give it a try, it is cheaper to thin epoxy 50/50 with xylene, but I say you're wasting your time.
Get the rot out by cutting if possible. Kill remaining rot spores with one of the borates made for the purpose (TimBor, etc) OR by saturating with old-fashioned ethylene glycol anti-freeze, (e.g., Prestone) which penetrates wood exceptionally well and is toxic to rot.
Grave in a replacement piece or sister with good wood beside the bad place.
Wayne
Apologies in advance for the long post...
Thanks as always for the assistance! Everyone on this forum is great. Figured I would just respond to these two posts since they captured everything people said.
There are three parts to the repair that I'm doing, and this is the order that I'm doing them in:
1. Repairing the weakened joist (which is what this thread is about).
2. Repairing a section of the flooring above the joist that was rotted and that I can't cut out. I put a picture of that below. I can't cut that section out because it would require going under the slide. That's just not an option for me because of A) lack of skill, and B) a place to do it. We travel full time and won't be at home base until December. I'm in an RV park right now.
3. Putting in sister joists to replace the floor that I cut out and offer support to the weakened joist.
The way I see it, I have a few options here. Please correct me if there are better ways to do this (again, without cutting under the slide.
Solution 1:
* Dig (or cut) out the rot
* Put a product like Timbor on the wood to kill any rot
* I do have CPES already so I am going to go ahead and put that in the wood that isn't visibly rotted, but might be rotting internally. I plan to just drill 1/2 inch holes at a 45 degree angle into the joist and inject the CPES. I figure it can't do any harm!
* Once all this is done I'll either patch the wood, like you guys suggested, or fill it with an epoxy. I need to go to Home Depot and see how much a rotary tool is that can make the cut. If it's more than about $100 I'll probably just use epoxy. My wife and I are on a debt free plan so we're trying to save money :).
Solution 2:
* For the section of floor that is rotted above the joist, I plan to just put some Timbor on it, patch it with epoxy, and then also put some CPES around it for good measure. That wood doesn't need to be super firm because nobody ever puts direct weight on it. There is another joist right beside the one that is rotted, underneath the slide. There's a gap of only about 3 inches between the two. So that section of floor just needs to be firm enough to not sink when someone puts a little pressure on it.
Solution 3:
* Slap in some sister joists and make a couple of squares, lay new flooring down.
Does all that seem about right?
Also, here's a follow up question: Do you guys have any tips for making the sister joists not squeak? I'm definitely not a carpenter! I've read that putting epoxy between the joists and then screwing them in is the way to do it, but I'd like to get it right the first time!
Thanks
Edit: Forgot to link the pic to the section of flooring that I'm going to patch (step 2). - https://www.dropbox.com/s/2eigoi3exwkxtws/2015-10-05%2011.18.14.jpg?dl=0
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
