RoyB
Mar 06, 2017Explorer III
I use the clear sealant from the hardware store. Be sure to observe your removed lens for a possible WEEP hole which should be on the botttom to be able to drain off any water that might get into your light assembly. Otherwise the area may fill up to where your light socket is and will then drain inside your RV... Some lens have the weep hole and some don't...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
