DutchmenSport
Dec 02, 2014Explorer
Brown substance... could be worse .. it could be green slime! ;)
Actually, your hose leading to the outside is leaking or missing, causing your refer to drip down the sides of something. Water droplets then pick up coloring in the surface it touches as it drips (wood, metal, dirt, oil, grease, anything), and picking up the color and depositing on the floor.
As other stated above, check that hose. More than likely, that's the problem.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
