- MEXICOWANDERERExplorerYA KOW YA GOT A PROBLEM WHEN YOU POP THE BATTERY HATCH AND FIND -THIS- ATTACHED TO YOUR BATTERY
- bigfootfordNomad III
stevenal wrote:
I thought all appliances were off. Does the fridge light work even when the fridge is switched off? Don't forget about the anti-condensation heater on the door seal. I disconnected mine to ensure it doesn't get switched on accidentally.
Not suppose to... You can test it if it has a lever to turn on/off the light. Think all Dometic's have the lever.
Yep, that anti-condensation heater can eat that battery.
Jim - stevenalNomad III thought all appliances were off. Does the fridge light work even when the fridge is switched off? Don't forget about the anti-condensation heater on the door seal. I disconnected mine to ensure it doesn't get switched on accidentally.
- bigfootfordNomad IIIkyle86 you have done excellent! Front of the class for you!
Jim - NinerBikesExplorerAnd that's why you do an electrical power audit, because all those little electrical suckers add up fast.
- kyle86ExplorerYall are awesome! I did what some of yall suggested. Found out the tv antenna was drawing .2...
Then i pulled the fuses and found the culprits. Below are the amp draws at the battery with each individual fuse pulled.
Radio/lp det 1.2 amp
Fridge 0.4 amp
Rear 1.6 amp
Center pump 1.5 amp
Front 1.6 amp
I pulled both the lp detector/radio fuse and the fridge fuse and amp draw went to 0.1
Looks like radio/lp detector pulls 0.3-0.4 by itself
Fridge drawing 0.8 by itself... Then I found out the fridge light was stuck on !!!! Pulled the bulb and total amp draw went down to 0.7. I turned on the lp for the fridge and it went to 1.1 amps
I pulled the radio out and pulled the internal fuse for the led and presets which was only worth .1
So now that I am down to 0.7/0.8 with everything off but lp detector, I am much happier!
Gracias to all who replied!!! I will be investigating solar power and generators next! :D - afinepointExplorer
bigfootford wrote:
Quote afinepoint:
"Thanks Bigfoot. I thought it was high as well. I'll look around. All I know of are the detectors and a Tire Minder booster which is wired into the lighting circuit.
Regarding addition power sources. I don't understand the design of the electrical system of a trailer. Every load in a house goes through the electrical panel. What's the point in a breaker box if you're going to bypass it? "
Well 2 different systems... the 120vac system is like a house and wired as such...
But the 12vdc system is like a car/truck in a way....
Battery has a fuse link
Fuse panel under the hood
Fuse panel under the dash
And there may be fuses else where....
Jim
You are so right. Got to thinking about it and the vehicles came to mind. Thus my deleting the comment minutes later. - afinepointExplorerOkay, the actual draw is 1.5 amps. I was using a different meter and had not set it up correctly. I can not find any other fuse boxes or power panels.
- bigfootfordNomad IIIQuote afinepoint:
If you have the owners manual for the trailer there may be locations for the fuses and their function.... hahahaaaa probably not... A major sore point for most rv consumers.. No wiring diagram..
Jim - afinepointExplorerThanks Bigfoot. I thought it was high as well. I'll look around. All I know of are the detectors and a Tire Minder booster which is wired into the lighting circuit.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
