- pianotunaNomad III
MFL wrote:
My lowest is just below 100. That is when the AC fan is set to auto, and both the fan and compressor start up nearly the same time.
However this low voltage, is just a second or two, so you'd have to be watching the meter closely. It quickly returns to 112-116, depending on other electronics running.
I don't feel this quick spike is hurting anything, and is normal.
What are others thoughts, as to very brief low voltage, on AC startup?
Jerry
I think that there will be spikes. Some folks on other threads have mentioned as low as 65 volts (iirc). That would concern me. And other campers on the same loop would have the spike/brown out happen to their RV's too. - pianotunaNomad III
CA Traveler wrote:
BruceMc wrote:
Maybe - resistive loads will have lower amps with lower voltage. Inductive loads like motors will have higher amps if they maintain the same horsepower.
The lower the voltage, the higher the current draw... Things are cooking somewhere!
Years ago I measured my A/C, lower voltage resulted in lower amps because the motor produced less HP. Several others reported the same.
Not suggesting low voltage is OK...:B
92 is seriously LOW!
Interesting on the measurements. I've not seen that happening--but to be fair I was not looking either. I merely suffered without roof air. - pianotunaNomad III
BruceMc wrote:
That's tough on electronics. The lower the voltage, the higher the current draw... Things are cooking somewhere!
Only inductive loads are bothered.
Which is why I invested in an autoformer. Lowest I've seen with the autoformer is 108. I have it set to cut in at about 113. - MFLNomad IIMy lowest is just below 100. That is when the AC fan is set to auto, and both the fan and compressor start up nearly the same time.
Jerry - BoomerwepsExplorer102vac but it shut down my EMS so I couldn’t read lower.
- CA_TravelerExplorer III
Not suggesting low voltage is OK...:B - CA_TravelerExplorer IIIHot summertime, A/Cs blasting, older park 92V. EMS had disconnected.
Quiz: 30A pedestal, 160V, hint open neutral - Why? Of course this happened at 10 PM. - BruceMcExplorer IIIThat's tough on electronics. The lower the voltage, the higher the current draw... Things are cooking somewhere!
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 27, 2025
