- FreightguyExplorerThis is the original fuse. I have never replaced it, and yes it does reset as I now have brake lights again.
- wa8yxmExplorer IIIAs I suspected when I first looked at the photo:
Buy BUSSMANN BY EATON 21220-00 MINI CIRCUIT BREAKER online at Newark element14, an authorized BUSSMANN BY EATON distributor.
That is a circuit breaker... You can get a replacement at most all auto-parts stores
A fuse blows once.. A circuit breaker can reset and trip many times.. I had one fail on my A/C in this rig.. Since the diagram shows a fuse.. not a Breaker,,I saved much on hair cuts before I found it and replaced it. - MEXICOWANDERERExplorerTwo types of breakers
1. Resets automatically
2. Resets ONLY after supply power has been chopped then restored - TeetonExplorerIn all my years have not seen a auto reset fuse use on brake lights. I'm thinking someone put it there. Maybe for a problem?? I'd put a regular atm 20 fuse and see if it blows. If it dose not leave the atm 20 fuse in and done.. If it blows fix whats doing it.
- bob213Explorer
- I would replace with same. Put the # into Amazon or Google.
midnightsadie wrote:
that fuse says 20amp, pretty good load to trip it. its trying to tell you some things not right.
Yeah some was not alright! Got that fixed though. - midnightsadieExplorer IIthat fuse says 20amp, pretty good load to trip it. its trying to tell you some things not right.
- RoyBExplorer IIDid find this online that looks similar
BUSSMAN MINI-CIRCUIT-BREAKER
You can replace yours with a standard ATM type fuse. The beauty of the circuit breaker is it will trip your circuit when overloaded and can be reset (some auto-reset after a few seconds) to use again. NO REPLACEMENT required.
Roy Ken
