darsben
May 15, 2016Explorer II
The button in the first picture appears to be a circuit breaker.
I would not believe the panel until I used a good VOM to confirm the battery voltage. If I were troubleshooting I would disconnect the batteries from all loads and measure the voltage. I would then charge the batteries with a GOOD battery charger until full. I would then reconnect the battery to the system and look at the reading on the panel. I would then figure my next step from there.
At 11 volts where the lights very dim? Did the TV work at all.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
