Moffittclan
May 15, 2016Explorer
darsben wrote:
The button in the first picture appears to be a circuit breaker.
I would not believe the panel until I used a good VOM to confirm the battery voltage. If I were troubleshooting I would disconnect the batteries from all loads and measure the voltage. I would then charge the batteries with a GOOD battery charger until full. I would then reconnect the battery to the system and look at the reading on the panel. I would then figure my next step from there.
At 11 volts where the lights very dim? Did the TV work at all.
The lights were good and the TV/satellite were still working. I think tomorrow I'll measure the voltage at the batteries and then start the coach and measure it and see if it increases...But I still need to locate the solenoid because I don't think the battery boost button is working either....
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
