Naio's avatar
Naio
Explorer II
Aug 04, 2017
What is this under my van?
When I was shopping for a new used van, I saw these on some of the ones with fiberglass tops. I figured that they had previously been wheelchair vans and it was a compressor or something for operating the lift.
But the van I ultimately bought has this thing, and it did not have a raised roof until I put one on. AFAIK, the van had one owner, who used it for towing a TT.
Like on the ex wheelchair vans with lift removed, on my van the bit that looks like an electrical junction box on a hose / cable is not attached to anything at the other end.
Whatever it is, can I remove it and put my batteries here, just behind the rear axle? There is, sadly, no space farther forward unless I go above the floor. Should I do that instead? If put them in the axle space, I will add more heat shielding on the adjacent exhaust pipe, could use advice about that, too!
Thanks you all, always.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 11, 2026
