MrWizard
May 10, 2017Moderator
this is what happens when i go off and start hunting stuff
12v under cabinet LED strip lighting
(4) lights, daylight white, comes with 120v power supply and controller and remote
each light is 11.8" long
could be used without the power supply, used in series or separately with switches
complete ready to use, no DIY extra parts
think i might buy a set
1) Bright Dimmable, convenient to adjust three level brightness; Turn up/down for other brightness,Great Application for Under Cabinet, Over Cabinet, Display Cabinet, Work Bench, Bookcase, Shelf, Closet, and More!
2) Easy to install:You can use those Accessories to install it or just use 3M tape to fix it under the cabinet light(3M tape is not include)
3) Each panel can replace 9W fluorescent tube,80 percent more efficient than incandescent lighting
4) working voltage DC 12 V, which is touchable and safe to children?You can either use the DC12V power supply directly or use the power it include
5) Each light is 3w 250LM ,Life time of 50,000 hours
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
