mrkoje
Jul 12, 2016Explorer
Matt_Colie wrote:Sam Spade wrote:mrkoje wrote:Matt_Colie wrote:
Please do not parallel 12V jars. Even if they were side by side on the assembly line, by the end of the third week, they will not like playing in parallel. If you are lucky, you end up with capacity * 1.7. It will more likely be 1.5.
Please explain ...
Please search a bit.
Gross oversimplification summary:
If the two are not perfectly matched, part of the capacity of the stronger one will be expended trying to charge the weaker one. And when charging, the weaker one will sap off more of the charge.
And if one should fail completely, disaster can occur.
The disaster is rare and I think his 1.7 estimate is closer until they get really old but 6 Volts in series really are better.
Sam,
Thanks for picking this up before I got back here. Yes, that may be a gross oversimplification, but if we explained it in more detail many eyes would glaze over. There are so many important variables, that it is difficult to get arms around, but please believe us.
I have always loved a line from the original Stargate. Colonel Jack Anderson (Richard Anderson) was listening as the tech-savey lady explained how something worked. At the end, he looked at her and said,"That was a complete waste of a perfectly good explanation."
What I understand that you are saying is that by taking a 12v battery and connecting it in parallel with another 12v battery that because of differences in the two (even if they are the same battery model) will only produce approximately 1.5x capacity instead of 2x that would be expected?
Just for quick arguments sake - wouldn't it really depend at which rate you are using the batteries to determine how much usable capacity that would be usable?
Are you referring to a known scientific model here or an observed effect because of the low quality controls on typical 12v batteries say found at Walmart in which the rated capacities vs actual capacity could be substantially different from battery to battery?
I've tried researching a bit on what you are explaining and unfortunantley I have not come across anything that supports this claim yet. Im not saying I don't believe you at all. I just want to see the science of what you are saying.
Can you post a link to what you are referring to? My eyes don't glaze over when it comes to stuff like this.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
