time2roll
Jul 12, 2016Nomad
Sam Spade wrote:There is no fight. The battery that has a higher resting voltage simply discharges to the level of the other and then they just sit peacefully.
If the two produce different voltages, they will be "fighting" each other.
Go ahead and equalize two identical batteries (that have been used in parallel) at the same time and then let them sit disconnected on the concrete for a week. Measure the resting voltages to quantify the difference. Post your results.
For the OP: 35 amp is fine for 1 to 4 batteries.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
