harold1946
Jul 14, 2016Explorer
Sam Spade wrote:harold1946 wrote:
Mrkoje asked you for a link supporting what you stated, where is it ???
I=E/R That's my link.
How many people fuse their battery banks ????
Thought so; If one makes statements that can not be supported, accept by precision guesswork then it does not exist.
Don't have a clue, but the ones that are aware of what a catastrophic failure can do will add one if the coach builder did not.
I would make a wild guess that most are not many even aware what one does or where it should be located.
bighatnohorse had a failure earlier this month and it blew off the top of a single battery in a string of two. No other damage was done, not even to the second battery in the string.
A fuse is much cheaper than replacing anything that could be damaged.
The monies, RV or life you save may be your own.
The old adage still hold true, (ignorance is bliss) have a blissful day.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
