scarletfire's avatar
scarletfire
what size fuses?
Hi guys,
hoping the experienced gurus here might take a moment to give a newb a little time and expertise.
just got used 2000 phoenix pop-up a few weeks ago (my 1st rv and 1st experience with DC) i do HVAC repairs for living so OK with AC.
there is no info with the camper that tells me what size fuses it should have. not sure if the right sizes are in there now.
problem i'm having is with the dometic Model RM2354 3 way, single door fridge.
works great with 120 VAC and propane but if turned to 12v it blows a 5 amp fuse in the little breaker/fuse panel inside the camper (not outside). the furnace quits working also when that 5 amp fuse blows. lights are ok
i downloaded the manual and it lists a 3 amp control system fuse and 5 amp AC heater fuse in the power module. the 12 VDC heater is listed as 30 amp (in line blade fuse).
VDC is all new to me, but it seems like a 5 amp is a little low.
do i need to take to the local RV dealer and have them figure out what size fuses are supposed to be in the 5 fuse slots or is there an easy way to check amp draw (like i would with my amprobe on VAC.
thanks for your consideration.
Bob
  • scarletfire wrote:
    Hi guys,
    Bob
    Hi Bob,
    Hoping the newb would respond back to info provided and followup questions asked
    In a nutshell, that model pulls 12.5 amps just for the DC heating element alone. So a 5 amp fuse is going to blow all the time. (see page 11 of the service manual for the DC requirements). In addition, the DC element was not designed for continuous use but rather to maintain cooling while "traveling".
    Just to add, the 5 amp fuse probably is for the DC control portion while on A/C or Propane; not the D/C heating element. You need a separate dedicated line and fuse if using the D/C full operation for the heating element if your RV wasn't wired for it.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I will say this again. On a Pop UP you likely have one small 12 volt battery. I would disable the 12 volt heater element (pull the big fuse on the refrigerator fuse board if needed) I would not use the 12 volt option EVER. 12.5 amps the other person (Who clearly did the research.. thanks) said. 100/12 is 8 and change. but with Peukert's law, you get about 1 hour of operation if you are lucky before your battery is damaged.
  • 3-way fridges DC Heating element is for maintaining fridge temps during transit NOT for cooling fridge down, not for use w/o means of battery charging/maintaining battery voltage
    DC option to be use when trailer is connected to tow vehicle and tow vehicle charge line active.....
    PERIOD
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
