Lynnmor
Feb 22, 2019Explorer II
K Charles wrote:Dutch_12078 wrote:
The recommended drill size for a 5/8" (.6250) slip fit pin hole is 21/32" (.6262).
ASME says 21/32 is the right size hole for 5/8 bolt for a close fit but 21/32 is 0.65625
It is not a bolt that is tightened, it is a pin that is loose and takes side loads. With a hole that is larger than the pin, there is a single point contact and that will cause more rapid enlargement. Ideally there should be a size for size fit, but some clearance is necessary due to location tolerances.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
