bpounds
Feb 22, 2019Nomad
Ed_Gee wrote:
This is not rocket science. His pin fits everything else he tried except the hole he drilled. Obviously the hole he drilled needs to be enlarged.
I agree with you on this part. About 1 minute with a Dremel tool will probably take care of the problem.
The most common problem with cheap receivers and draw bars, or home made copies, is that they didn't get the hole dead nuts on center, or they drilled from each side instead of through, and the holes are not in alignment. Size isn't usually a problem, because a 5/8" drilled hole (not reamed) will have all the clearance needed.
Those of you who doubt, dig out your dial caliper and go measure a few receivers and draw bars.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
