- NMDriverExplorerBigger is better in this case. 1/2 in. drive and 18 plus volts. Yes a 3/8 lithium will work especially if it is at least 18V, but I need the 1/2 in drive for other things like my lug nuts.
- naturistNomad IIShort answer: no.
The truth is you need to put a little torque on those jacks for them to actually do anything. I tried with a 9.6 volt 3/8 inch cordless drill/driver and was less than thrilled with the stability. I'm now using a 1/2 inch cordless drill/driver that develops 425 inch-pounds of torque (18 volt) and find it does the job well.
If you want to use a 4 volt cordless screwdriver, good luck. Waste of time IMHO - jeomeliaExplorerThe jacks are to stabilize the trailer not to level. A 3/8" lithium ion battery drill would work. When the threads on the jack become dirty you need a drill that you can hold on to and has decent torque.
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 17, 2026
