marcarolle's avatar
marcarolle
What size of power drill for scissor jack socket?
Hi,
What is the minimum strength of a cordless drill to use with the scissors jack socket? Would a 4V cordless screwdriver be sufficient for my "new to me" Gulf Breeze 26RKS (approx. 5100lbs) ?
If not, what would be the minimum? Size could be an issue (the smaller the better).
Thanks!
Marc
  • Bigger is better in this case. 1/2 in. drive and 18 plus volts. Yes a 3/8 lithium will work especially if it is at least 18V, but I need the 1/2 in drive for other things like my lug nuts.
  • Short answer: no.
    The truth is you need to put a little torque on those jacks for them to actually do anything. I tried with a 9.6 volt 3/8 inch cordless drill/driver and was less than thrilled with the stability. I'm now using a 1/2 inch cordless drill/driver that develops 425 inch-pounds of torque (18 volt) and find it does the job well.
    If you want to use a 4 volt cordless screwdriver, good luck. Waste of time IMHO
  • The jacks are to stabilize the trailer not to level. A 3/8" lithium ion battery drill would work. When the threads on the jack become dirty you need a drill that you can hold on to and has decent torque.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
