Glad you found it useful. I have used it for a while now and it is one of the better ones I have found. Keep in mind that 8 AWG wire is only rated for 40A so if you want to install a 50A as per a PP, you will need 6AWG.
SoundGuy wrote:
kampinguru wrote:
http://www.paigewire.com/pumpWireCalc.aspx?AspxAutoDetectCookieSupport=1
Here is a calculator. Says 10AWG
I've been using this Voltage Drop Calculator for it's simplicity but the Wire Size Calculator you've provided is really user friendly as well ... thanks for the link! :)
