BFL13
Oct 18, 2015Explorer II
First, you need a 120v power source that can run whatever charger you get. Generally, you need EG a Honda 1000 for up to a 45 amp charger, or a Honda 2000 for up to a 60 amp charger. But if the charger is PF- corrected, a 75 amper will draw the same 120 as a non-PF 60 amper.
So, for a pair of 6s (that can take 70-80 amps just fine for Bulk, BTW) you can use this 75 amper as a portable charger if you have a Honda 2000 equivalent to run it.
http://www.bestconverter.com/Boondocker-BPCM-75-75-Amp-Adjustable-Power-ConverterCharger_p_587.html#.ViQ2c3mFNjo
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
