Mobile_sport
Oct 18, 2015Explorer
BFL13 wrote:
First, you need a 120v power source that can run whatever charger you get. Generally, you need EG a Honda 1000 for up to a 45 amp charger, or a Honda 2000 for up to a 60 amp charger. But if the charger is PF- corrected, a 75 amper will draw the same 120 as a non-PF 60 amper.
So, for a pair of 6s (that can take 70-80 amps just fine for Bulk, BTW) you can use this 75 amper as a portable charger if you have a Honda 2000 equivalent to run it.
***Link Removed***
I actually have a Honda 2000 genset that I modified into a component sytem
Honda engine mounted in my rear bumper
Honda electronics mounted in the vans interior
Deleted Hondas fuel tank , fuel line run to vans gas tank.
Working on installing a starter so I can remote start it.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
