BFL13
Nov 14, 2015Explorer II
Mobile sport wrote:BFL13 wrote:
First, you need a 120v power source that can run whatever charger you get. Generally, you need EG a Honda 1000 for up to a 45 amp charger, or a Honda 2000 for up to a 60 amp charger. But if the charger is PF- corrected, a 75 amper will draw the same 120 as a non-PF 60 amper.
So, for a pair of 6s (that can take 70-80 amps just fine for Bulk, BTW) you can use this 75 amper as a portable charger if you have a Honda 2000 equivalent to run it.
http://www.bestconverter.com/Boondocker-BPCM-75-75-Amp-Adjustable-Power-ConverterCharger_p_587.html#.ViQ2c3mFNjo
BFL13 I just wanted to say Thanks , I bought the Powermax 75 and really really like it , Thanks for the recommendation.
OK you are now the Official Guinea Pig for running the PowerMax 75 amper with a Honda 2000. Please confirm that it runs at 75 amps for a time (bulk stage) at around 14.8v on the Honda 2000 as power supply without the Honda conking out. And do you have to start with eco-off and then turn eco on or can you get away with an eco on start up from cold? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
