Dave_H_M's avatar
Dave_H_M
Explorer II
Oct 22, 2015
What Sticks to Coroplast?
I have a couple of patches i need to make on the undercover of the fifth wheel.
Having trouble getting something to bond the coroplast to the under cover, which I assume is coroplast also.
My genuine gorilla tape does not do the job. Poor results with silicone also. I am also cleaning both surfaces with mineral spirits and drying first.
What is a guaranteed, never come off way to stick the patches on there?
I am thinking eternabond but if it works like my roll of gorilla tape, I would hate to invest the time and money.
thanks
  • That is a good idea Mex.
    That stuff is nasty to work with but may be the cat's meow.
    Ford man, what kind of sealant are you referring to?
  • Aerosol foam insulation (in a can) seems to stick like crazy to everything. It even grabs Teflon.
  • When I cut access holes in mine , I had gotten some storage containers (black) with lids.. I cut the flat part off the lids out and cut the access hole smaller.
    After I was done , I applied some Heavy Duty black adhesive/sealant around the edge . placed the patch on it and used small self tapping stainless steel screws to secure. It held up till the day I got rid of the trailer..
  • Gjac's avatar
    Gjac
    Explorer III
    Just remember there are two types of bonds chemical and mechanical. Coroplast is a thermoplastic and most are chemically inert so solvents won't prepare the surface well for a chemical bond. Most thermoplastics respond better to a mechanical bond. So if you sand the surface well to roughen it adhesives will adhere better. I use Shoe Goo for these type of plastics. Epoxies or caulking like 3M 5200 will also work if the surface is abraided well.
  • Gorrillia tape the other thing to do is some 1×2 on the inside and screw a piece of plywood to the 1×2 you can also buy some belly tape from a mobile home place
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
