rtate
Jun 05, 2013Explorer
rtate wrote:
I pulled out my Norcold refrigerator to replace a vent fan on the back. I tested out everything prior to slidong it back into its opening and things seemed to work fine.
After slidong it back in place i couldnt get it to turn on, so I started checking things..
No 120 volt power hooked, just 12 volt.
Where power goes to the frig I only got 5.7 volts. I disconected the the 12 volt power feed and checked power at the feed without being hooked up to the frig. I got 11 volts. At the battery I got 13 volts.
Looks to me like I have two different problems. First the power drop from the battery to where it feeds the frig. I need to trouble shoot that, but why the heck am I getting a 5.7 volt reading when hooked up to the frig? Not sure I know where to start. I disconnected the connection to the eybrow but didnt seem to make any difference.
HELP!!!!!
Sorry but I gave some bad info on my oroginal post. If I disconnect the plug on the board that feeds the eybrow ( temp control, off/on switch etc) I get a voltage of 11 volts where the 12 volt power connects to the frig. So, I assume there is a problem with the eyebrow. Why does it give me a voltage reading of 5.7 volts at the power connection to the frig with the eyebrow hooked up but 11 volts with the eyebrow disconnected? Any ideas would be welcome.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
