tenbear
Jun 05, 2013Explorer
You have a high resistance connection somewhere in the 12v line from the fuse panel to the eyebrow. Check the voltage at the fuse panel on the refrig side of the fuse. May be a loose screw where the wire to the refrig is connected to the fuse panel. Could be any place in the refrig wire that 2 wires are joined.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
