- 2oldmanExplorer III'm not really sure how a 'digital' gauge is any better than a slider. I mean, how do you know? What's the gold standard in gauges? Does a digital readout mean that the internal workings of the actual pressure sensing device are any better?
- BruceMcExplorer III
- BurbManExplorer IIII use the Accu-Gage by GH Meisner & Co. Accurate and easy to use. I like the short hose with the clip on so I can easily adjust pressure. Also hard to find a gauge that goes to 100 psi when I need 80 in the truck.
Accu-Gage website.
- Iraqvet05ExplorerI use the Accutire brand which seems to be consistent between the 3 I bought for our vehicles. I'll never go back to a mechanical dial or slide gauge unless I want a "ballpark" reading.
- Victory402ExplorerI had a digital tire gauge that went out of calibration on me. It cost me a set of tires. I'm staying with the tried and true slider stick!
- GordonThreeExplorerI use a slider type, also have a mechanical gauge type and a digital gauge on my inflator. All three of them read different values for the same tire, go figure. The slider seems to be the closest match to the OEM pressure sensor on my truck.
- DrewEExplorer IIII use a stick/slider type. Even if it's a pound or two off, that's not the end of the world nor a real safety concern if the target pressures are set responsibly.
I did just "upgrade" my car's stick gauge to a cheap dial type because the stick one I used previously self-destructed, blowing apart into pieces as I was checking the pressure. I don't have any reason to believe the cheap dial is necessarily any more accurate; it just happened to be on a good clearance sale when I needed a replacement. - wildtoadExplorer III use slider type for big tires. Seems to work just fine.
- 2oldmanExplorer IIWhat's wrong with the slider type?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
