pianotuna
Aug 06, 2016Nomad III
Greenrvgreen,
Yes I have the 3012.
So far as I am aware the problem may be related to only my installation. The folks at Magnum were no help at all, which is unusual. Fortunately I can remove it from the circuit easily and go back to the OEM converter.
It maddening, because it works just fine with SOME gfci outlets, and instantly trips others.
In your shoes, I'd look at the Victron and Outback hybrid units, as well as Magnum. I would still use male and female plugs so I could "patch" around any difficulties. If I had not done so there would be times where I would not be able to use shore power at all.
One other minor issue is that with the 3012 I can not do "double conversion" It kills the reverse polarity fuses on my PD 40 amp converter more or less instantly. I have a work around for that, too (yes, a set of male and female plus). With my old Cobra 2500 watt MSW inverter that was not an issue.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
