RoyB
Sep 19, 2014Explorer III
My ALWAYS ON 600WATT PSW Inverter is mounted on a vertical cabinet outside wall. I have a round vent (LOWES) where air can be pulled in from the POPUP OPEN area. I have also added small round vents (LOWES) between all of my wrap around cabinets starting at the entrance door going all the way around the inside of the trailer to the front tent bed area where we normally sleep.
I have a 6-inch axial mounted fan in the WFCO converter/charger compartment where my push-in shore power cable was installed which is on an attic fan thermostat(LOWES) which I have set for 80 degrees.
This allows me positive air flow from hallway mounted round vents on both ends of the total wrap around connected cabinets. When the 6-inch axial fan kicks on it draws air from the floor area of the popup and exhausts out an outside type louver fan vent from the converter/charger compartment. I can also just open the cabinet door where my 600WATT INVERTER is installed as well to get more air flow going.
I haven't really noticed the 600WATT or the 1500WATT Inverter getting real hot. I was also planning on installing another outside RV type louvered vent from this cabinet as well but never did it.
You can get an idea of my connected floor cabinets from this floor plan drawing...
OUTSIDE RV Louvered vents (AMAZON) looks like this
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
