wopachop's avatar
wopachop
What type of battery lugs?
The lug on my main ground wire isn't looking too great. It's crimped and loose in spots.
I don't own the crimping tool. Do most DIY people use solder or best to invest in the tool?
Do I want a tinned lug? Silver solder or be a lead head?
Hoping to replace just 1 lug for cheap. Instead of buying in a nice kit with multiple sizes.
  • Boon Docker wrote:
    Easy Install Battery Lug
    Those are "universal" battery terminals. Not as good as factory pre-made, but plenty adequate. Make sure to coat the terminal and any exposed wire with grease (Vaseline works fine) to prevent corrosion.
    And most place sell those for $1-$2 a piece !
  • My battery ground cable went to a grounding bolt on the frame. I replaced the cable with a 4ga starter cable.
    • You need genuine 60/40 electronics solder
    • Hardware store solder will not work
    • Amber color hardware solder FLUX is cheap and effective for larger cables
    • Shine old copper with a sharp utility knife blade until all the strands are brand new copper penny bright. Scrape the strands then reshape to round with fingers
    • Use Vise Grips to hold a TIP of the terminal or lug with the wire tube facing upward
    • Heat the work not the solder with a torch
    • Pur a dab of flux in the bottom of the terminal wire well
    • Melt enough solder to fill the well half full
    • USE A RAG TO HOLD THE WIRE AS IT'S GOING TO GET HOTTER THAN HELL
    • Gently stick the cable copper into the well while playing the torch on the terminal body
    • THIS IS A SLOW PROCESS
    • When the solder is ready to WICK UP into the copper strands it will
    • Do not push down on the cable it will push molten solder out of the terminal
    • Heating may take a minute or so
    • When the solder WICKS UP the copper strands EASE bit by tiny bit the cable down into the terminal well
    • PATIENCE! this takes time be a craftsman! When copper is fully immersed, pour a bit of water down the wire insulation and watch it sizzle
    • This does NOT cause a cold solder joint!
    • Cool the work, then examine it. Good solder looks like chrome, bad solder looks like dried chrome aluminum paint.
  • I was able to take cable to West Marine and make up a new one using their tools. I bought new cable, crimp terminals and de-oxidation compound from them. the marine multi-strand cable worked great. Coated cable prior to crimping with the de-ox compound.
    No charge for using their tool.
  • I think auto suppliers like NAPA will make up crimped cables. My local marine supplier does the same. I've ordered cables to length with different ends from marine wire suppliers.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
