gmcman's avatar
gmcman
What would cause a shudder under load
This is on my stock tranny (4L60E) in an 02 envoy, I was taking my tandem axle 14' trailer (about 1300 lbs) for it's annual inspection and I felt a shudder under load. I'm almost positive the TC was locked in OD...about 50-55 MPH....usually is.
I was accelerating and when I was between 1/3-1/2 throttle, TC remained locked and the vehicle started to shudder but was progressive and not a hard shudder but almost felt like a bad U-joint. When I apply the gas at 50 ish, there is no shudder but when I hold the throttle position the shudder comes in lightly then amplifies and goes away when I let off.
There is no spike in RPM like a clutch pack slipping but I don't know...shifts fine and runs fine the rest of the time.
I have replaced the separator plate, 1-2 and 2-3 acc pistons and have the vette servo. Trans has 182K miles and fluid looks great, replaced 10K miles ago.
Fluid has always been replaced at 30-40K intervals
Rear was changed from factory 8.0" to a 9.5" SF and I just switched to Redline Heavy Shockproof fluid.
U-Joints are new and driveshaft was shortened and balanced.
Just curious if this could be a trans issue or not and if so where to look.
  • dannydimitt wrote:
    dannydimitt wrote:
    the shorter the drive shaft becomes , the possibility of a driveline shudder
    increases . The degree of angle of the output shaft needs to be VERY close to the same angle of the pinion shaft on the rear end. This can be done using an inexpensive angle gauge from the home depot or other places . If the truck has leaf springs in the rear the angle of the pinion can fairly easily be changed with the use of simple wedges available through e-bay , amazon or parts houses,placed between the axle mounting plate and the leaf spring.
    I had the same problem with a Jeep Cherokee that came from the factory doing this and was finally fixed by myself when I learned of this procedure
    Good luck,
    Here is the part # for the angle finder I used
    Swanson tools part # AF006M
    A plethora of information can be gleaned from this web site
    www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
    Good luck,
  • the shorter the drive shaft becomes , the possibility of a driveline shudder
    Good luck,
  • My guess is the driveshaft. It is the only non stock item and logically the first place to look. Having sold and installed a lot of rebuilt driveshafts over the years I have had shakes from initial installation to various times and mileages after installation. Issues have ranged from the yokes being slightly out of phase to my supplier trying a slightly cheaper u-joint in an attempt to improve his bottom line. It could also being something new like the rear main loosening up and the crank is flexing. There are lots of possibilities. At the mileage you have mentioned I would buy a new vrhicle instead of throwing money at a possibly hard to locate shake.
    Randy
  • this could be it, but maybe the TT tongue weight is causing the axle to bend backwards and the angle of the drive shaft is a little higher thus causing the stutter you describe.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
