dougrainer
Sep 29, 2018Nomad
Air pockets in the tank are usually a design problem of Atwood water heaters. Not Suburban's. Have you tried popping the outside pressure relief valve and see if it spits air also? I would open the Pop off valve and allow it the flow for about 30 seconds and then close it. Doug
