timmac wrote:
Whats a Good Brand for a Inverter but not a Prosine, 2000 to 2500 watts, good quality low price. It appears my Procine 2.0 is my problem and from the complaints on Amazon and boating forums that use them all say they are high price junk..
timmac,
You've gotten a lot of feedback, most of which it appears that you have ignored. I'm a long-time ProSine 2.0 owner and I can state unequivocally that they are not "high price junk". Mine runs my convection-microwave day in and day out, it powers my fridge when I am on the road, and I frequently use it to run the A/C.
The problems I have seen and heard about are typically the result of a poor installation and/or insufficient battery capacity.
Based on your description, the problems you are experiencing are a result of low voltage to the inverter. Either you wiring is too small, too long, your batteries cannot provide sufficient current without sagging (I suspect that it is a combination of all three).
Hoping to operate a ~1500W load (e.g. microwave) from a pair of cheap Group 31 FLA batteries without the inverter shutting down is wishful thinking. If you only have room for two batteries, consider two Group 31 AGM's (e.g. Lifeline or Odyssey). More (or larger) batteries is better.
Before you go wasting money on another inverter, measure the voltage at the battery terminals and again at the inverter terminals while you are operating a heavy load (a simple way to do this is with a hair dryer with multiple heat settings). Then report back the battery voltage AND tell me the "Inverter Low V Shutdown" value that is set under the "Advanced Menu" under setup in your ProSine.
If you have your heart set on a new new inverter that does what the ProSine 2.0 can do, then you should be looking at the Magnum MS2012 or the MSH3012M. Please let me know if you go this route... I'll be happy to take the old high price piece of junk off of your hands ;)
Cheers,
-MS
