Fisherman
Jul 28, 2015Explorer
If your multimeter has the 10A option, great. Undo the positive main terminal from the batteries, insert the multimeter between the positive post and positive wire. It will give you a reading. Now go to your 12V fuse panel, pull one fuse at a time until the reading goes to zero. Likely culprits are LP/CO detector, AM/FM radio, propane fridge if it's on. I always disconnect my positive wire from my batteries when not at the trailer, the solar panel remains connected to charge the batteries.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
