bigfootford
Jul 29, 2015Nomad III
Make sure that 9100 has the Charge Wizard controller with it!
The 9100 is a single stage charger without it.
http://www.progressivedyn.com/charge_wizard.html
Check to see if your fridge is a 3 way... 120vac, propane and 12vdc (for cooling). If it is and you leave it on Auto it will switch to 12vdc mode and you will not be doing much charging of your batteries going down the road.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
