02CumminsGuy
Jun 22, 2016Explorer
DrewE wrote:n
Many people use nylon webbing straps, such as are used for holding down loads in a pickup truck. A couple of D hooks secured to the floor of the box will give you something to hook them into.
It can be hard to find D hooks that are somewhere between "hold up a picture frame" strength and "hold down a minivan on a wrecker's bed" strength. I eventually came across these after some searching which seem about appropriate for the task.
So just to make sure I've got the idea, no tray or anything under the batteries. Then those d rings screwed to the floor and nylon webbing straps (ratchet straps?) in the d rings and across both batteries? That's so simple.
Thanks a lot!
