agesilaus
Jan 31, 2014Explorer III
Use a dry lubricant, silicone spray or some other type. The big box hardware stores have a rack full of spray cans with a couple of different dry sprays.
WD40 is not intended as a long term lube, WD means Water Displacement and it was originally intended to be used on wet connectors on Titan Missiles. The 40 means it was the 40th formula tried. It's too volatile and does not leave a long term lube film.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
