road-runner
Jun 27, 2021Explorer III
I can't speak for every WFCO converter. The one I observed worked as follows.
- Converter startup, (AC power applied)
- Converter attempts to supply 13.6 volts at its output.
- At 7 seconds after startup, if output voltage is 13.2 or less, boost mode is entered
- Boost mode continues for 4 hours
The wimpy wiring in most RVs makes it impossible for a low battery to pull the converter output down to 13.2. The converter isn't defective. It's that the converter design and RV design are not compatible.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
