grizzzman
Oct 25, 2016Explorer
My trailer had a line for the outside BBQ with a quick disconnect. I made an adapter for the disconnect to the bottle connection. Then I adjusted the regulator (less spring tension) This is the smaller Mr Buddy heater. The filter is needed if using high pressure. In you case a tee,hose and a quick disconnect would work.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
