Gdetrailer
Apr 28, 2019Explorer III
wopachop wrote:
I think the battery tender goes to 14.3 or 14.4v while my flooded batteries want 14.8?
Pretty sure the battery tender is 5amp. Im using it as a temporary charger to cycle the batteries in the garage once a week. Bought the new batteries for a camping trip back in Feb and didnt need them. Should have waited as im plugged in most the time.
Your batteries ARE seriously undercharged!
Even with a 5A charger your batteries may not ever see 14.3 or 14.4V for weeks. A 5A charger connected to a 210Ahr battery simply cannot sustain a high enough voltage until the batteries have been sufficiently charged to 99%. Only then will a 5A charger be able to continue to increase the voltage..
Your 5A might be fine for a small motorcycle battery, but for 210A GC batteries it simply will not cut it and soon you will be replacing the batteries and still wondering why you only got a yr or two out of them.
For proper charging, you NEED a REAL charger capable of min 10A-15A or higher. The higher the better.. Like I said, you NEED to wallop the batteries, small chargers simply are not able to provide a high enough continuous voltage to charge at a high rate.
You ALSO need to fully recharge the batteries AS SOON AS POSSIBLE, it is critical the moment you are back to get them charging AT A HIGH CHARGE RATE. The longer they sit around in partial discharge the more irreversible damage is done.
Good battery management makes the difference, not the brand, I have no issue getting 9 yrs out my one pair of GC batteries and they play a critical role since I depend on them to power my home fridge conversion.. Failure is not an option in my use..
For about $40 with 20% off coupon you can get an old school non smart 2A/10A battery charger at Harbor Freight.. If you watch for sales they often have them for $29!
HERE
You do not need a "smart" charger or multi stage charging for what you are doing, you simply need a charger which can get your discharged batteries filled up as quick as possible.. That HF charger will do the job within a day or two and you do not want to leave it on for much longer than that.. Otherwise you will boil the batteries dry!
Alternately if you find a deal for a 35A-45A RV converter you could use that instead.. Perhaps watch your local Craigslist for used WFCO units.. Folks tend to replace them with better units but they can function as a battery charger with multi stage charging..
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 27, 2026
