Chris_Bryant
Feb 16, 2015Explorer II
There are 2 issues- any moisture in the cylinder could freeze the regulator. This is fixed by getting a real LP place to inject anhydrous methanol into the cylinder.
The other problem is not having enough heat to vaporize the LP- keep the cylinders as full as possible. Keep both cylinders on, though that can run both cylinders empty at the same time. A light bulb under a cover could work to add heat.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
